vandruten
Indonesia
Post by a user on the group, by Albert D.
"After reading much discussion and speculation, I decided to do some real time testing with Way point and Orbit missions to verify exactly what happens at the end of missions when battery gets low..
The simple summary is that, with Return To Home set as the Failsafe action, at low battery the P3P will initiate RTH.
I set up two way point missions and also ran some orbit missions. (These were planned for all of the final portions to occur in an open field at 30-40 feet altitude, 200' to 500' from my observation point, with no obstructions.)
For the first mission, I set up and ran a 14 minute mission with the end of mission Finish Action specified as None. I ran this mission once normally to verify the flight paths, then flew back and landed. I ran the mission again with a fresh battery. About 10 minutes into the mission, I physically powered off my remote controller, to create a Loss of Signal condition. The mission continued to the end of the full 14 minute mission, then the P3P immediately initiated and successfully executed Return to Home, climbing to the 150 ft RTH altitude I had set, then returned and landed safely, about 5 feet from the take off position.
For the second mission, I added numerous circuits at the far end of the field, creating a mission that would take almost 25 minutes to complete (7-8 minutes past the expected battery endurance). I ran the mission with a fresh battery and again physically powered off my remote controller after about 10 minutes, to create a Loss of Signal condition. The mission continued until about 18 minutes, then the P3P executed RTH, returned to home point and landed safely. (Checking later, I had about 7% battery left.)
My third test mission was to run an orbit mission to end of battery. When battery power got low enough, the P3P initiated RTH (message: aircraft requesting return to home, will go home in 8-7-6... seconds). At the end of the countdown, the orbit stopped, the P3P climbed to RTH altitude, came to home point and landed safely (8% battery left). I was going to test orbit with loss of signal next, but I decided to do the following test to verify the RTH was happening based on when the vehicle calculated how much battery needed to go home, instead of low or critical battery warnings..
My final test mission was to send my P3P out, run a 3-row panorama (pano mode, mostly for fun and to run the battery down some), then start an orbit about 5000' from home point. Again, when the vehicle calculated it needed the remaining battery to come home, it initiated RTH (without any intervention from me). This time, RTH was initiated with almost 30 % battery (well above my low battery warning) and the P3P came to home point and landed safely. (I thought it said 8% when it landed, but when I re-checked the batteries after I got inside, it showed 6% left.)
From previous reports and discussion, I had expected the vehicle to operate each mission or orbit until critical battery, then land wherever it was. I was pleasantly surprised to see that, with the Failsafe mode set, the P3P safely brought itself home when it reached the RTH battery level, regardless of RC signal or Loss of Signal.
I am flying Phantom 3 Pro with latest firmware v1.6.0040 on aircraft and RC. Running the latest Litchi 2.7.1 on a Samsung Tab S2 9.7 32 GB LTE with Android 5.1.1" |
