Phantomski
Flight distance : 14869882 ft
So when u pull your card into a pc, the videos are not on it? Which Phantom? Power it up at home, no props, do as you always do.. start recording video.. Look if you display on the tablet all looks happy, no icons about SD card issues? What if you click the bar that says "gps safe to fly".. that will also tell you stats on your sd card...
You can reformat your card from there, but DO NOT, until you figure out what happened to old videos. How about stills? Do they show up on the SD card ok?
What folders did you look at? There are folders on the SD card, right?
(I am assuming u r using some SD reader). You also could connect your Phantom to a computer via USB, and look at file transfer that way, but SD direct read should work best and fastest.
Throw us some details, and maybe someone will figure it out for you! The phone.tablet video is only 720xwhatever.. I forget.. not HD resolutions at all....
