Icon in map view?
2027 32 2016-6-15
patrickhaering
Flight distance : 160614 ft
What does the icon in the bottom right corner of the map view do?  It looks like a padlock or fingertip tilted 45 degrees. If I tap it it turns blue and then turns white again.
2016-6-15
hummingbird.uav
Flight distance : 8378937 ft
If you had been flying then switching to map view you would see a trace of the flight.  Pressing the icon will erase the trace from the map.
2016-6-15
DJI-Ken
Flight distance : 1515312 ft
Correct, as hummingbird posted it's an eraser and erases the green flight path.
2016-6-15
patrickhaering
Thanks for clearing that up. I find that there's a lot going on in the app, so I spend quite a bit of time reviewing it offline. That way I can concentrate on flying!
2016-6-15
Airspace Explor
patrickhaering Posted at 2016-6-15 11:35
Thanks for clearing that up. I find that there's a lot going on in the app, so I spend quite a bit o ...
And there's an app setting to enable/disable the flight trace.
2016-6-15
DJI-Ken
Airspace Explor Posted at 2016-6-16 03:05
For me I leave it on, if you ever lose signal and instead of performing a RTH you cab just follow the green line home.
2016-6-15
Airspace Explor
DJI-Ken Posted at 2016-6-15 13:10
For me I leave it on, if you ever lose signal and instead of performing a RTH you cab just follow  ...
... to avoid the obstacles that a straight line to home point would encounter.
Now what's the best route home?
2016-6-15
DJI-Ken
Airspace Explor Posted at 2016-6-16 04:16
Not following what you are saying. My suggestion was to follow the green line home since you have no signal.
Either way if you follow the green line home or a RTH, both would hit an obstacle on the way home unless you have a P4.
2016-6-15
Airspace Explor
DJI-Ken Posted at 2016-6-15 13:25
Not following what you are saying. My suggestion was to follow the green line home since you have  ...
If you've lost signal, how would you know if the aircraft is following the direct route home?
The straight line between aircraft and HP can't be removed, afaik.
If you didn't fly directly (LOS) to your target location in order to avoid obstacles, etc., then yes, it would be wise to re-trace your steps following your outbound flight route trace on the map to avoid the same obstacles on the return leg.
2016-6-15
DJI-Ken
Airspace Explor Posted at 2016-6-16 04:45
If you've lost signal, how would you know if the aircraft is following the direct route (green lin ...
When you lose signal it's most likely going to be video but you still have great RC signal. The video takes so much more data and you'll lose that first (P3 Pro/Adv)
2016-6-15
Airspace Explor
DJI-Ken Posted at 2016-6-15 13:48
When you lose signal it's most likely going to be video but you still have great RC signal. The vi ...
Isn't the straight line colored green and the route actually taken a shade of gray?
You're advising to fly home by retracing the route taken when outbound, right?
UPDATE: No, the straight line is orange and the actual route taken is green.
2016-6-15
DJI-Ken
Airspace Explor Posted at 2016-6-16 04:54
You're advisi ...
if you are high up in the air you can can follow the straight line home. That's all I'm saying.
2016-6-15
rodger
Flight distance : 20145135 ft
patrickhaering Posted at 2016-6-15 14:35
Great move. Practice in ATTI mode as well.
2016-6-16
DJI-Ken
rodger Posted at 2016-6-16 19:30
Great advice, everyone should be totally confident flying in ATTI mode. The day will come when there's a GPS signal loss fro whatever reason and you need to know how to control it by yourself.
Many crashes can be easily avoided by learning ATTI.
My suggestion is to do it in a large field with strong winds, if you can be proficient with that then you'll be just fine.
2016-6-16
soundbyte58
Flight distance : 300761 ft
DJI-Ken Posted at 2016-6-16 07:04
Great advice, everyone should be totally confident flying in ATTI mode. The day will come when the ...
I bought myself a little Blade nano when I got my P4 so I could practice on a drone that can take some punishment. You also have to maintain altitude with a bare bones quad, and that adds a little more complexity.
2016-6-16
DJI-Ken
soundbyte58 Posted at 2016-6-16 23:08
I bought myself a little Blade nano when I got my P4 so I could practice on a drone that can take s ...
Perfect start, especially flying and being confident with something harder to fly than the Phantoms is good.
BUT, the DJI aircraft so much technology built into them that you also need to know the whole manual and know all about it's features and it's limitations.
2016-6-16
darrenphillips1
Flight distance : 501913 ft
Try a few other cheaper toys  to improve your proficiency
And then you will have better skills and knowledge to enjoy your
Awesome Dji  equipment
2016-6-16
rprobinette
Flight distance : 69 ft
If you fly in the atti mode will the quad hold altitude when I let go of the sticks?
2016-6-16
endotherm
Flight distance : 503241 ft
rprobinette@pin Posted at 2016-6-17 01:47
Yes it will.
2016-6-16
soundbyte58
rprobinette@pin Posted at 2016-6-16 08:47
Yup, but the slightest air movement, or if the gyro is off a tiny bit it'll drift. I was flying my P4 inside a 700 seat theatre last week and the air conditioning vents were blowing it around.
2016-6-16
AG0N-Gary
Flight distance : 700846 ft
darrenphillips1 Posted at 2016-6-16 10:39
And then you will have better skills and  ...
Obviously shot from down under.
2016-6-16
darrenphillips1
AG0N-Gary Posted at 2016-6-17 07:59
Down under Adelaide South Australia
2016-6-16
skipilot1
Flight distance : 1557398 ft
DJI-Ken Posted at 2016-6-16 04:25
I find the green line to home helpful and reassuring. I find the white tracing line a distraction. Are you saying that if I turn off flight tracing in the app then I will also lose the green line to home?
2016-6-16
DJI-Ken
skipilot1 Posted at 2016-6-17 10:42
I find the green line to home helpful and reassuring. I find the white tracing line a distraction. ...
if you disable "Show Flight Route" and that will make the white line flight path not show up.
You do still have the direct straight line from you to the aircraft.
2016-6-16
rodger
DJI-Ken Posted at 2016-6-16 10:04
Very true Ken and it is a ton of fun. I first started flying in ATTI in a 50 Acre open field. Now I do it in a small Orchard on my property. And yes, a windy day is a challenge. We take GPS and IMU for granted and it is really working overtime in a moderate wind. Pretty amazing.
2016-6-18
DJI-Ken
rodger Posted at 2016-6-18 19:11
Very true Ken and it is a ton of fun. I first started flying in ATTI in a 50 Acre open field. Now  ...
Yes we do take all the incredible technology features for granted.
2016-6-18
skipilot1
DJI-Ken Posted at 2016-6-17 11:14
You  ...
I disabled it and the green line back to home went away also.
2016-6-18
DJI-Ken
skipilot1 Posted at 2016-6-18 23:47
You are correct, on the Phantom3 Standard I still had a straight line, I just tested the Inspire and there was no line.
2016-6-18
rodger
DJI-Ken Posted at 2016-6-18 11:39
I was amazed with the capabilities of the Phantom starting with my very first one many years ago now. It would do so much for so few dollars. That still holds true to this day.
2016-6-19
DJI-Ken
rodger Posted at 2016-6-19 19:10
I was amazed with the capabilities of the Phantom starting with my very first one many years ago n ...
Yes indeed for sure.
If you think about the technology in DJI aircraft especially the P4, is really is incredible.
2016-6-20
rodger
DJI-Ken Posted at 2016-6-20 11:08
If you think about the technology in DJI aircraft especially the P4, is reall ...
It really is Ken. Think back as little as 10 years. What we have today is fascinating.
2016-6-20
DJI-Ken
rodger Posted at 2016-6-21 09:34
Yes for sure indeed.
2016-6-20
DaveNC
Flight distance : 28560 ft
Thanks for that question and answer. I have searched high and low, watched numerous tutorials about DJI GO, searched the P3S manual, searched forums, and this is the only place I've seen the answer.
I suggest that DJI include this in the next version of the manual. It tells what the other icons do, but not this one.
Dave
2017-1-19
