Firmware and Gimbal
1635 8 2015-1-22
christian
Hi Folks, since yesterday i am a proud inspire member. As DJI recommends i did the firmware update but i am not 100% sure if everything is up to date now. Attached you´ll find a screenshot which shows the current status of the aircraft and controller. It would be super nice, if anybody can verify the correct firmware.
Second thing i was wondering a little bit, is that the gimbal seems to be not in an 90 degree angle to the copter. I have also attached a picture which shows the little offset in the x-axis. It´s not that much, but just to be sure, this is OK.
Thanks folks for your feedback on this.
Have a nice one,
Christian
2015-1-22
DJI-Terry
China
Hi, Christian,
Your firmware are the latest already. As per the slight offset, it is within tolerance. No worry, you can pan via your Tx. Have fun and fly safe
2015-1-22
christian
DJI-Terry Posted at 2015-1-22 19:00
Hi, Christian,
Your firmware are the latest already. As per the slight offset, it is within toleran ...
Thanks Terry, good to know that everything is OK. Regarding the gimbal, is there a way to correct the offset? Cheers, Christian
2015-1-22
DJI-Terry
Hi, Christian,
Not for pan at the moment. But you can give pan command from your Tx to correct it.  Will add it into the wishlist to our R&D dept.
2015-2-25
lrwskyfilms
christian Posted at 2015-1-22 19:42
Thanks Terry, good to know that everything is OK. Regarding the gimbal, is there a way to correct  ...
Hi, you can calibrate the gimbal, that should sort it. Cheers Mark
2015-2-25
vincentgossuin
Flight distance : 29318 ft
Luxembourg
Hello DJI Terry
You said that a "Christian" that's good update, but at home I have another set aperture .see below image.
Can you tell me why it is unlike update?
thank youu
Bonjour DJI Terry
Vous dite que a "Christian " que c est la bonne mise à jour, mais chez moi j ai une autre mise ajour voir image.
Pouvez-vous me dire pourquoi c est différence de mise à jour?
Merci
2015-3-2
DJI-Autumn
vincentgossuin@ Posted at 2015-3-2 19:51
Hello DJI Terry
You said that a "Christian" that's good update, but at home I have another set apert ...
@Vincent all your firmwares are same with mine, they are latest version.
2015-3-2
vincentgossuin
Luxembourg
DJI-Autumn Posted at 2015-3-2 20:03
It appears that all the machines have different update. I do not know why he has time diference ??
thank you
Firmware Christian
Firmware Vincent
2015-3-2
Arctictern
For some reason my firmware seems to be different for camera and gimbal. Did the latest update etc
Any ideas?
2015-3-2
