DJI-Ken
Flight distance : 1515312 ft
No you do not, the only thing you cannot do with cellular (iPad WiFi has no GPS also) is follow me as the device needs a GPS.
Also, without cellular you will not have live map data but you can easily cache the map of your flying area while you are at home on your WiFi. Or you can just use your phone as a hot spot so your iPad will have WiFi to get the map data. But that does not work with follow me, but if you must use follow me, then just use your phone anyways as it's much smaller and easier to manage while your walking around having the aircraft follow you. |
