Flight Raptor
Flight distance : 3014675 ft
Not sure if you got your answer elsewhere, but this is what you need to do:
1) With battery #1, startup your quadcopter (with the firmware on the MicroSD card) and let the Phantom Automatically start its update
- This will update the quadcopter and the battery
- this process could take 15-20 mins or so
2) With your phantom off, put in battery #2 and startup your quadcopter (should still have firmware on MicroSD card)
- This will update battery #2
- This process will most likely take less than 5 mins
3) With your phantom off, put in battery #3 and startup your quadcopter (should still have firmware on MicroSD card)
- This will update battery #3
Everything should be updated and ready to go.
NOTE: On the last battery, once the firmware is done updating, you'll need to turn your Phantom OFF and then back ON to actually fly it right away.
