Aircraft Battery - Times Charged
1036 11 2016-6-20
Airspace Explor
In preparation for a 'battery calibration', I took a screen capture of the Android DJI GO Aircraft Battery page just before takeoff, when the battery was 100% charged, and again after landing after being flown until Critically Low Battery (10%).
What I see is the Times Charged is one more after the flight when I returned from the airpark than at the end of the flight.
The second battey shows a Times Charged bumped by 2.
What's gong on here?
UPDATE: Re-installed first battery. Times Charged is same as seen after I returned from airpark. Motors were not started both times away from the airpark. In fact, they would not start via CSC (battery too low).
Times Charged before flight
Times Charged after flight
After full charge - Times Charged unchanged but gained capacity
2016-6-20
Airspace Explor
It would be helpful to show the battery serial number on the Aircraft battery page for those of us using more than one battery. A screen capture would then show to which battery the measurements apply.
2016-6-20
Airspace Explor
Battery 1 now 100% charged after a deep discharge (2%) - Times Charged DID NOT CHANGE! There seems to be a delay in the Times Charged value.
The Total Capacity is 10 more mAh and the Battery Life remains 90%.
2016-6-20
DJI-Ken
Flight distance : 1515312 ft
The battery cycles will show another charge when you deplete the battery down to under 50% or more then charge it back up.
Also, in the battery tab "Advanced" is the serial number.
2016-6-20
Airspace Explor
DJI-Ken Posted at 2016-6-20 13:28
The battery cycles will show another charge when you deplete the battery down to under 50% or more t ...
I captured the counter when the battery was depleted (below 50%) immediately after a flight and again before connecting the charger. There was no charge between those two captures.
2016-6-20
DJI-Ken
Airspace Explor Posted at 2016-6-21 05:01
I captured the counter when the battery was depleted (below 50%) immediately after a flight and ag ...
Try taking it down lower to 10-20% then see what it does.
2016-6-20
Airspace Explor
DJI-Ken Posted at 2016-6-20 14:04
It was depleted to 7% as shown in the OP.
2016-6-20
DJI-Ken
Airspace Explor Posted at 2016-6-21 05:11
I see, seems it skipped one but it's good now as it reads two charges fight?
2016-6-20
Airspace Explor
DJI-Ken Posted at 2016-6-20 14:13
I have not been keeping a log of charges so I have nothing else with which to compare.
2016-6-20
DJI-Ken
Airspace Explor Posted at 2016-6-21 05:16
Write the number of times charged on the battery and then make a small mark for each charge and in a few months see if they are the same.
2016-6-20
fans00e011b4
Philippines
Recharging lipo battery packs and the replacement of lost electrolyte, a natural process in wet-cell batteries, staves off permanent sulfation. When a battery is allowed to remain in a state of sulfation, either from lack of use or from lack of recharge, it tends to lose both capacity and life.
2016-12-17
rchobby
BEAST 150A
It’s more about the performance, it is about the fashion. It’s about competition. Our team has been dedicating lots of time and efforts to improve the design to bring you this completely stunning product- Beast series. Beast series ESC are well designed and tested and fine-tuned by the experienced driver proven to be a reliable quality ESC. On top of this, we make it more resistant to water. Not splash, it’s real waterproof. You can run your vehicles through the morning dew, down the muddy road, across the soggy snow or just about anywhere else you’d be interested in running a 1/8th scale RC buggy or truck. We are using today's state of the art micro components, The ESC delivers advanced tuning options for the hardcore racer. Whether you are into large scale or short course, Beast has what racers demand; reliability, precise control and unmatched power handling capability. Also for the sake of safety, we offer you the accurate voltage and temperature protection to make sure you are using within the safe limits. Wide range of parameter configuration and friendly PC interface setting make it even more perfect choice to gear up your vehicle.
Features:
1. Enhanced throttle response, excellent acceleration, strong brakes and throttle linearity
ztw brushless ESC
freewing Rc airplane
rochobby rc airplane
rochobby rc airplane UK
2. Using advanced software interface to set up or update the software or using programming card to make adjustments.
3. Using PC or programming card to program forward or reverse throttle limit
4. Using PC to program braking percent
5. Multiple protection features: Low voltage cut-off protection, over-heat protection and throttle signal loss protection
6. Compatible with NOVAK, LRP, ORION Sensored brushless motor
7. MOSFET design provides high-current output (1080 amp peak) with incredibly low resistance (.0003 Ohm)
8. Micro-fin aluminum heat sink dissipates heat.
9. Industrial leading edge waterproof design
Specifications:
Max continuous current: 150A
Burst current: 180A
BEC output: 6-8.4V adjustable, 3A
Motor type: 4 pole sensorless and sensored brushless motors
Battery: 5-18 Cell NiMH or NiCd, 2-6S LiPo
Suitable vehicles: 1:8 on-road and off-road cars/trucks
Operation environment: waterproof design allows you to use in nearly any environment
Resistance: 0.0002 Ohm
Dimensions: 55x48x37mm
Weight: 159g
source from http://www.ztwshop.com
2018-4-3
