DJI-Ken
Flight distance : 1515312 ft
Nice, glad you have them now.
Here's some notes I found that may help with your Mac.
And to reinstall the same firmware that's already on the aircraft, just format the SD card and and run the firmware update. If something didn't take for some reason then it should now.
This method will be more clear and detailed. But it is much more convenient to use Windows:
Here are the steps to access the .DAT files stored on the hidden SD card permanently mounted inside the Inspire 1.
1. Power up everything with the Inspire 1 as if you were going to fly (except the props), and launch the DJI GO App.
Enter the camera view.
2. In the MC Settings menu, choose Advanced Settings. You can find the MC Settings on the top left corner of the screen,
directly to the right of the Home icon.
3. Scroll down, and select Enter flight data mode.
4. The DJI GO app will prompt you to connect the drone to a PC or Mac via the USB to mini-USB cable included with your drone package.
Plug the regular USB plug directly into your Mac (not a USB extension port box).
Note: This was done using a 2013 iMac running OSX 10.8.5, there may be some differences with different models and OSX versions.
5. Once you connect the drone to your computer wait to see if by chance it does mount to your desktop.
When it doesn't, open the application Disk Utility.
6. Select the disk DJI DATA LOG. It will show listed in the left column of disks in Disk Utility.
You can select it even though it is not mounted to the desktop.
(Be sure to choose the root disk DJI DATA LOG file and not the DJI FLY LOG file).
7. When the disk DJI DATA LOG is highlighted, select the New Image icon in the top row.
This will present the dialog box shown, asking what to name it, where to save it and what format.
(I've chosen compressed with no encryption).
8. Be prepared to wait a long time. The amount of time depends on how many .DAT files there are.
The entire SD card could be full. The Inspire 1 records a .DAT file every time it is powered on,
regardless of flight or not. It only erases them when space is needed for newer files.
(I wouldn't start with the Inspire 1 battery less than 50% charged).
9. Once the Disk Image is created on your Mac, double-click it, it will un-compress to a new window
(in temporary RAM memory only). Drag the files you want from there to a newly created folder on your computer.
