Assistant Software Not Responding To Drone
1017 8 2016-6-26
seanybf
I have downloaded all the correct assisstant softwares for my Phantom 2 with H4-3D gimbal and my aim is to enable Naza Mode, and recalibrate my gimbal to angle the full 90 degrees (which so far will not go vertical or horisontal). However when i plug in my drone or RC the softwares are completly unresponsive, even though my laptop (Windows 8) shows they are connected. I have yet to find any help on this problem, so any help at all will be most appretiated.
Thanks , Sean.
2016-6-26
Northofthe49th
Sean,
What is the color of the lights in the lower left of the Phantom Assistant?
You should have a green light as in this pict. on the lower left...
Did you also download the DJI Win driver installer as none of the DJI Phantom  2 softwares will work without it.
2016-6-26
seanybf
Northofthe49th Posted at 2016-6-26 15:27
Sean,
The light that should be green is red and the blue is blue.
2016-6-26
seanybf
seanybf@btinter Posted at 2016-6-26 16:33
And yes i have the win driver installed as well
2016-6-26
Northofthe49th
seanybf@btinter Posted at 2016-6-26 08:34
are you plugged into the correct port on the Phantom, the one underneath the little flap?
Try another usb port on your computer as well,
And if none of the above are applicable,
delete all your software, completely uninstall
re start the install with the Win Driver first and go from there.
2016-6-26
seanybf
Northofthe49th Posted at 2016-6-26 16:40
Try anot ...
Yes and i have
2016-6-26
seanybf
Try anoth ...
I have done all of this already.
2016-6-26
Northofthe49th
Well o.k.,
Have you tried another USB Cable, or another PC if you have access to one,
I also presume you have the correct version softwares loaded for your bird...as there are numerous
http://forum.dji.com/forum.php?m ... mp;page=1#pid251592
Some p.c's need administrative rights enabled/disabled, there were numerous threads on some folks having similar issues. if this is a work p.c. and you do not have admin rights it might be locking you out.
2016-6-26
seanybf
Northofthe49th Posted at 2016-6-26 16:46
Well o.k.,
I do have full admin access, the cable isn't the problem as the laptop itself recognizes the drone is connected.
2016-6-26
