Screen recording
1324 15 2016-6-27
cloudycante
Flight distance : 558173 ft
It isn't a question about phantom itself actually, but... what do you use to record the screen of your tablet while flying?
I've been reading a lot on it, but couldn't find anything feasible yet, with this setup:
iPad Air 2, iOS 9, DJI Go App.
What to use to record it?
2016-6-27
Flight Raptor
Flight distance : 2705617 ft
Sorry, not familiar enough with IOS.  I could tell you a good one for Android, but that doesn't address your question.
2016-6-27
DJI-Ken
Flight distance : 1515312 ft
I edited your post to the correct spelling (you forgot the n)
for IOS, I used to use Air Shou to screen record, sometimes it works and sometimes it deosn't.
2016-6-27
gullisig
Flight distance : 7901365 ft
Iceland
DJI-Ken Posted at 2016-6-27 18:31
for IOS, I used to use Air Shou to scr ...
Have seen this one in use and seem to work well. Don't know if it works with Go App.
You can try its trail.
2016-6-27
DJI-Ken
gullisig Posted at 2016-6-28 02:40
You can try i ...
I used to use it with the GO app and use to work just fine.
2016-6-27
cloudycante
DJI-Ken Posted at 2016-6-27 20:42
I looked into it, but it seems it lost the ability to record screen with the last update, unfortunately I didn't install it when it was recording screen as main feature
2016-6-27
cloudycante
gullisig Posted at 2016-6-27 20:40
You can try i ...
It seems it had turned into a social network for gamers now
2016-6-27
04red6
Flight distance : 5484997 ft
Air Shou is still around, but you need a wifi connection to use the screen record. No idea why. I have it on my mini 4. You can find links and instructions on how to install it if you google it. But it is a waste of time.
2016-6-27
huntcool001
You need to jailbreak to make screen recordings work best on iOS. But I'm a bit confused, if there's cache of videos, why would people record screen?
2016-6-28
VisionAir
Flight distance : 954665 ft
huntcool001@gma Posted at 2016-6-28 18:10
You need to jailbreak to make screen recordings work best on iOS. But I'm a bit confused, if there's ...
Recording screen is useful if you want your On Screen Data overlayed on your recorded video.
2016-6-28
VisionAir
I have recently installed the HDMI module on my Phantom 4 Remote (AU$169.00) so now I can plug the HDMI into my MacBookPro and use the screen record function of the Mac, and with that Module you have the option to send clean video or video with On Screen Data I am also about to buy a HDMI video sender/receiver with it's own power supply I plug the sender into the Remotes HDMI out and the receiver into the HDMI in to the MacBookPro or any other HDMI input i.e. video monitor or Shogun, this gives me the ability to send and record the info from my iPad mini 4 to a remote screen/laptop so the client can see what I am shooting without having to look over my shoulder and because you can record the On Screen Data this set up is also very good for creating tutorials, I am about to buy an Inspire 1Pro as my Main RPA and this already has the HDMI output. I hope some of this info is helpful.
2016-6-28
Jkeller84
Flight distance : 396955 ft
Use the Litchi app
2016-6-28
drudis
For Android you can use screen capture on your phone.
(went out on the boat... forgot the SD card, and had to do lousy screen capture to get any video)
2016-6-28
DJI-Ken
VisionAir Posted at 2016-6-28 20:12
I have recently installed the HDMI module on my Phantom 4 Remote (AU$169.00) so now I can plug the H ...
Isn't the Macbook Pro HDMI port an output only?
2016-6-28
VisionAir
DJI-Ken Posted at 2016-6-29 00:29
Thanks for pointing that out, I just assumed that because HDMI is two way however after a little research yes you are right so this means I may have to invest in a Atomos Shogun, thanks for that Ken
2016-6-29
DJI-Ken
VisionAir Posted at 2016-6-29 19:39
Thanks for pointing that out, I just assumed that because HDMI is two way however after a little r ...
No problem, it would have been great if it were IN/OUT.
2016-6-29
