Power Sony A7s through P-Tap
1195 3 2016-6-29
dmcruley
Hi guys!
Can you tell me if it's possible to power the A7s through the 12V P-tap on the Ronin-m using this cable: ?
http://www.switronix.com/product ... &category_id=58
2016-6-29
DJI-Jamie
Flight distance : 112405 ft
This P-Tap should be fine for what you want to do. Just ensure that the cabling is able to be tidied without hindering movement.
2016-6-29
dmcruley
DJI-Jamie Posted at 2016-6-29 16:46
This P-Tap should be fine for what you want to do. Just ensure that the cabling is able to be tidied ...
Thanks! I'll give it a try
2016-6-29
DJI-Jamie
dmcruley Posted at 2016-6-29 23:32
The only thing that you may need to get is the Power Distributor accessory:
http://store.dji.com/product/ronin-m-battery-power-distributor
The A7 is a small camera, so you might get away with not needing it, but this would ensure that you have enough power going to it.
2016-6-29
