skipilot1
Flight distance : 1557398 ft
I see so many posts about compass errors and crashes due to compass errors. I am starting to wonder if some folks aren't using these things right.
I had read a post from an engineer explaining the sensor (IMU and compass) readings and what is a normal range. I always check as part of my pre-flight checklist. Apparently, normal compass readings are between 1450 and 1600.
I have calibrated my compass locally in the middle of a football field at least ten feet or more from where I emptied my pockets, took off my watch and phone. I have had no trouble with the calibration process. Before takeoff it generally reads around 1450 to 1480.
Last week I went from Atlanta to Ocean City, MD. I did a compass calibration in a playground area at least 20 feet from the equipment. The sensor readings were about 1500. I made some beautiful flights and had a good time.
Now I am back in Atlanta. I went to fly this morning. I checked the sensor readings and they were a bit over 1500. That made me realize that I had not recalibrated after driving 600 miles.
As it was still in the normal range, and I was in front of my house and did not want to calibrate on the street, I decided to take off. I kept the bird low for a bit and slowly raised height and distance. I had three flights of about 1500 meters each without a problem in GPS mode and using RTH after losing signal.
I will re-calibrate next time I go flying as it will be from a park or field. I am wondering if people who report compass problems are checking the sensors before flying to see if the compass readings are within the normal range and also keeping track of their readings so they would be alerted and question why the readings they usually get are significantly different even though they fall within the normal range. Perhaps they would catch some of these problems a lot earlier.
