FCC or CE in canada? how to know
7838 18 2016-6-30
Jetboys
Flight distance : 535020 ft
Can anyone advise how to know if the DJI app is running in FCC or CE mode. im in canada.
2016-6-30
darrenphillips1
Flight distance : 501913 ft
Go to you settings in Dji go app with RC and aircraft on and linked and enable maximum flight distance
If you are able to set it over 500 m you are in FCC if only 500 m or less you are in CE
It is automatically set by your location and region in the gps maps
Side note I am in CE in Australia but have heard (not tried yet) if you are using an iPhone or iPad go into its settings and change your region and time settings while being logged out of Dji go app then sign in it allows FCC in CE areas????
Good luck enjoy your flying
2016-6-30
Jetboys
darrenphillips1 Posted at 2016-6-30 21:28
Go to you settings in Dji go app with RC and aircraft on and linked and enable maximum flight distan ...
if you mean flight altitude not distance, then yes mine will not fly over 500m.
i thought i read that the U.S and canada was FCC
2016-6-30
darrenphillips1
Jetboys Posted at 2016-7-1 09:39
i thought i read  ...
No I did not mean altitude as 500m altitude is set for both CE and FCC
Look for enable maximum flight distance in settings it has a toggle for on off and when on you can set the distance you want
When off the flight distance will be unrestricted and depend on interference etc etc
It works as a geofence to stop your aircraft going past the set (by you ) distance
And if you can set this distance option greater than 500m then you must be in FCC mode area
If only up to 500m you are in a CE mode area
2016-6-30
Jetboys
darrenphillips1 Posted at 2016-6-30 21:57
Look for enable maximum fli ...
if i enable it then yes mine only goes to 500 but if i leave it disabled then a can go as far as i want.
so whats the point of having it max out at 500 when all i have to do to go farther is turn it off.
also, have you looked in your map and notice that all red circles are gone from "no fly zones" ie. airports
2016-6-30
darrenphillips1
Jetboys Posted at 2016-7-1 10:03
if i enable it then yes mine only goes to 500 but if i leave it disabled then a can go as far as i ...
You wanted to know what mode you are in
If you can't set it higher than 500m your in CE mode (a simple way to find out)
It's there as an option so that you can control how far it can go
I.e. You let someone else fly and don't want to be searching for 1000's of meters to find your aircraft when they crash it
2016-6-30
wmcvey
Flight distance : 904364 ft
darrenphillips1 Posted at 2016-6-30 22:13
If you can't set it higher than 500m your in CE mode (a s ...
I think your wrong on this. I far as I know the limit for that setting is 500M everywhere in the world. And if you want to go further, you turn it off. Nothing to do with CE or FAA. I live in Pa. USA so that's FAA for sure, and my setting max out at 500m. But to the OP, I believe Can. is FAA.
2016-6-30
egconstruger
Flight distance : 26906 ft
Dominican Republic
and with android tablet, can you do it too?
2016-6-30
starfighters
Flight distance : 1358215 ft
Hi...
If i'm not wrong CE it's a european community mode with the limitation for this part of the globe,i mean it's a GPS signal you receive that's once recognized by drone put it in different mode,CE instead of FCC decision is made by the FW on board,being in canada i suppose you are in FCC modality.
Anyway i've never noticed in the app wich mode you are flying with
2016-6-30
DJI-Ken
Flight distance : 1515312 ft
starfighters Posted at 2016-7-1 14:47
Hi...
If i'm not wrong CE it's a european community mode with the limitation for this part of the g ...
Correct, the US is FCC and any CE country will have the limitation. When you power up the aircraft the GPS location determines which mode it will be in.
2016-7-1
mochorm
Flight distance : 940148 ft
Good day Ken,
The OP is asking specifically when in Canada are our transmitters in FCC or CE mode.
This is a multiple choice question FCC or CE ?
Secondly is there a way for us users to tell if your in FCC mode or CE mode?
In Canada we can be either so it's important for us to know!
TIA
2016-7-1
DJI-Ken
mochorm Posted at 2016-7-1 23:31
Good day Ken,
It's 3.5km in CE and 5km in FCC for all aircraft except Standard and 3 4k. Those are 500m CE and 1,000 or 1,200 FCC.
I don't know how to tell which mode it's in.
2016-7-1
mochorm
DJI-Ken Posted at 2016-7-1 11:12
It's 3.5km in CE and 5km in FCC for all aircraft except Standard and 3 4k. Those are 500m CE and 1 ...
Thank You Ken! Appreciate you telling it like it is
I've read our Canadian Government regs on the subject and because of NAFTA (North American Free Trade Agreement) , vendors are allowed to sell products here that adhere to the FCC regulations.
So I'm going out on a limb and going to say we have FCC mode, as it would be the cheapest option for DJI to get their birds into Canada.
Ken can you tell me where I can put a request in to have DJI update the DJI Go app so that it tells us  what mode we are in. The info. is obviously available in the controller so why not show us...
2016-7-1
DJI-Ken
mochorm Posted at 2016-7-2 01:50
I've read our Canadian Government regs on ...
It's been already requested long ago. Don't know if they will ever add the option or not.
2016-7-1
thegaz99
Flight distance : 2289144 ft
darrenphillips1 Posted at 2016-7-1 11:28
I thought Australia was FCC?? Will have to check.
2016-7-1
darrenphillips1
thegaz99 Posted at 2016-7-2 05:55
CE in Australia
2016-7-2
Braveheart
Flight distance : 151 ft
I am in Canada and with the new firmware 1.5.40 with DJI Go app 3.1.23 I no longer get 2.4 or FCC. Drone is losing rc signal at very close range. No option to change to ce or fcc or 2.4 or 5ghz?? Not to happy right now. Bird is grounded till new firmware update I guess??
2018-1-7
solentlife
Flight distance : 1087530 ft
Latvia
Easiest way to know for sure ... use Magic Power or Icarus - they have diagnostic built in to tell you exactly what power output you have ...
With respect ... Kens post does not answer OP's question
"It's 3.5km in CE and 5km in FCC for all aircraft except Standard and 3 4k. Those are 500m CE and 1,000 or 1,200 FCC.
I don't know how to tell which mode it's in."
All it does is state the open ground ranges and not countries applicable.
There's probably a list somewhere online ?
Nigel
2018-1-7
Mark The Droner
Flight distance : 2917 ft
This thread is over a year and a half old - and still no definitive answer whether Canada is FCC or CE mode?  How is that possible?
2018-1-7
