Enkeixpress
Flight distance : 297497 ft
Thanks for the posts guys. I have hardly any doubt in my mind that the Phantom 4 will surpass the Bebop 2 in terms of flight stability, distance/range and having confidence when flying it. The one thing I hate with the Bebop 2 is the shoddy live stream quality, it looks very messy even when the drone is close by, it's never a clear smooth picture. Same goes for the recorded 1080p footage, not perfect, usually losing focus when flying at a high speed. I also hate how you have to purchase the big skycontroller separately in order to save money, and it doesn't even extend the drone's range in a correct manner. You need to be in a very open area with hardly any wifi devices in the area to fly up to 2km. I've only reached around 1.2 km and that was only because I was heading in a direction in a large park where there were no houses and buildings of any sort.
Most times I can only get the Bebop 2 to around 400-500 metres or so in distance in my neighbourhood, above those houses. I've seen YouTube videos of guys piloting the Phantom 4 over cities and around huge skyscrapers, close to 400 metres in the air, and at distances of at least 1.5 km. And the live stream on the iPad is always 720p HD.
Put two guys side by side. One holding the P4's controller and the other holding a Parrot Skycontroller. I'd honestly find it pretty laughable to see with the large size difference between the two controllers. If you've seen the Skycontroller, you'd know what I'm talking about, huge amplified 36 dbm antenna block on that thing. And a wireless range extender is just as good as the thing in extending wireless range, which is shocking. Why is the P4's controller so much smaller and yet able to provide the same if not more range for its drone? Suppose it comes down to using better and much newer technology.
The Bebop 2 guy has flown his Bebop 2 across his neighbourhood, or at least has tried to going about 500 m in distance and an altitude of 50 m, and is currently waiting for his drone to return to home because it's lost signal. Whereas, the Phantom 4 guy is there flying his drone 450 m in altitude and flying in large circles around his neighbourhood in sport mode, with almost zero to no lag on his iPad, connected to the P4's controller.
I'm fairly sure I'll be seeing a huge difference when it comes to flying the Phantom 4 in comparison to the Bebop 2, according to those many YouTube videos I've watched. It's the drone I should have bought in the beginning. At least that's how I feel about things so far. We'll see how my thoughts change once I've had a month with it.
