Osmo X3 Audio is Sped Up?
1456 1 2016-7-4
Rastus
Flight distance : 605210 ft
Just received my replacement for a defective Osmo X3.
I've recorded  30 clips over the last two days. The audio is sped up on every one. It sounds like chipmunks talking.
I'm shooting 1080p 30fps. I opened a few clips in the program Media Info. Under the Audio section everything looks correct except it states "Frame Rate: 46.875 fps (1024spf)" Has anyone had this problem? I'm pretty unimpressed with the Osmo so far.
In fact here's the whole audio section...
Audio
Format                                   : AAC
Format/Info                              : Advanced Audio Codec
Format profile                           : LC
Codec ID                                 : 40
Duration                                 : 20s 587ms
Bit rate mode                            : Constant
Bit rate                                 : 128 Kbps
Channel(s)                               : 2 channels
Channel positions                        : Front: L R
Sampling rate                            : 48.0 KHz
Frame rate                               : 46.875 fps (1024 spf)
Compression mode                         : Lossy
Stream size                              : 322 KiB (0%)
Title                                    : DJI.AAC
Language                                 : English
Encoded date                             : UTC 2016-07-03 12:56:11
Tagged date                              : UTC 2016-07-03 12:56:11
2016-7-4
DJI-H.C
Flight distance : 13602 ft
Hi,normally the sped up audio issue is caused by firmware. Flashing the latest firmware (again) often solves the issue.
Go to http://www.dji.com/product/osmo/info#downloads and download
2016-7-4
