Kuminatano
Flight distance : 154249 ft
Argentina
Hi Everybody!
I have various Phantom 3 (pro, adv std) and I read a lot of posts trying to solve my problem....
I'd read when DJI was uploading new firmwares for our birds, many people had problems with theirs updates.
Well... With the lastest frmware P3X_FW_V01.09.0060, all my problems appears!!
I did EVERYTHING, and when I say EVERYTHING its EVERYTHING jajaj (Not sendind DJI RMA obviously)
Well... In several post, I noticed a common problem, when an update was failure or corrupt, some internal devices on our bird (mainly on gimbal I think) put in an state like DEVICE NOT DETECTED..... then I think again, and think and think and I asked myself why DJI make firmware that kill devices...but... well... nevermind...
Continuing, I chechk internal hidden logs, and a lot of people have (for example) like this:
[00121230]Version checking[2]...
[00121314][03 05][00] v34.2.0.9 -> v34.2.0.9
[00121418][03 06][00] v2.4.20.18 -> v2.4.20.18
[00121600][04 00][00] v1.44.0.0 -> v1.44.0.0
[00121734][11 00][00] v1.8.0.0 -> v1.8.0.0
[00121873][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00121945][11 01][00] v1.8.0.0 -> v2.0.0.33
[00122043][12 00][00] v1.10.0.0 -> v1.10.0.0
[00122143][12 01][00] v1.10.0.0 -> v1.10.0.0
[00122242][12 02][00] v1.10.0.0 -> v1.10.0.0
[00122348][12 03][00] v1.10.0.0 -> v1.10.0.0
[00134900][15 00][00] device not detected.
[00135024][17 00][00] v1.1.1.7 -> v1.1.1.7
[00135161][17 01][00] v1.0.2.7 -> v1.0.2.7
[00135238][19 00][00] v255.255.255.254 -> v1.0.8.96
[00135298][01 00][00] v1.30.5036 -> v1.30.5036
[00135350][01 01][00] v1.30.5036 -> v1.30.5036
[00147907][08 00][00] device not detected.
[00148019][09 00][05] v3.0.0.10 -> v3.0.0.10
[00148074]Packet upgrade failed at version checking.
And I stop here... Do you see highlighted in red?
Well my question is: WHERE I CAN FOUND A FIRMWARE TO RESOLVE THIS ISSUE?????????? Because this state was generated by a failed upgrade firmware process or simply by the latest firmware in my case...
Every DJI firmware tested finish with an error and this kind of LOG, and also with red light and continue error sound.....
Is there a solution to fix this issue???
Thanks!!!!
Alex
