jason.fawbush
If the bin file for the firmware is on the SD card, I assume it's trying to update firmware. Mine took longer than 15 minutes to update, and it did beep loudly most of that time. I read the online firmware updating procedures, and it said loss of lights and the beeping were normal. Just pay attention to the red/green LED on the front of the camera gimbal base. It should be flashing green and red. Once it's solid green, it's finished. If you've already updated, pull the SD card and delete the firmware file. Otherwise it'll probably look at that file and try to update everytime you power it up. Someone from DJI may chime in if I'm wrong. |
