MD_Icarus
I just realized I cannot use my male to male adapter cable , which then connects to the P4 USB female to micro adapter cable!
I had to locate the original cable which came with the P4!
Thanks for your help!
I am planning to do a complete calibration, and maybe, if I feel brave, I may do the firmware upgrade. My current is 0301.
I assume I only have to run the latest?
If anyone can offer the correct sequence which worked for them, I would really appreciate it.
I have read the instructions, and the manual, but I see different options.
I am tilting towards doing the firmware first using the DJI assistant.
Then remove one battery and insert the other one.
I am a bit confused here as to what I do? I wont be able to upgrade again, since I will be current. How is the new battery going to get updated? Do I have to save something on the sd card?
Finally, I am planning to upgrade the DJI Go up using the iphone.
I then rebot and everything should be up to date.
Did I miss or skip something?
