Gimble issue
407 1 2016-7-7
mikealtilio
After a crash, the gimbal makes a very vibrating/grinding sound. I checked the backplate and the shaft flat spot is in the same position as the camera orientation so that's correct. It does not have it correctly on its axis like it used to. Any suggestions?
2016-7-7
DJI-Paladin
Flight distance : 2408 ft
Hello mikealtilio, I'd suggest you to calibrate the IMU and gimbal at first. If the calibration doesn't help, please get in touch with our US tech support and send it in for fixing. Here is the contact information: 北美地址.JPG
2016-7-7
