Controller has switched to P3 Proffesional! from P4?
734 0 2016-7-8
hakan
Flight distance : 19354 ft
Sweden
Hi!My controller has switched from being a P4 controller to a P3 proffesional controller!?
It can connect to the P4 for a short time (3 seconds) then it disconnects.
I've tried reinstalling the GO APP and did a install on a fresh android phone without any change.
The problem seems to be that the controller has switched to P3 professional.
The version in the controller is 1.6.0 and the version in the P4 is v1.1.411.
In the GoApp it detects the P4 as a P3 Proffesional.
If I just start the controller and then the Go App and holds down the button on the top left for a downgrade of software it says
Equipment: P3 Proffesional
Firmware Version: 1.6.0
If I just power up controller and P4 it seems that the controller has no connection to the P4, for example the gimbal tilt wheels has no effect.
I got the P4 yesterday, upgraded the P4 with the latest software using the DJI assistant 2 and did one flight today that worked fine.
I had a bit of gimbal tilt so I did a IMU calibration, after that things went bad and it switched to being a P3 Pro controller!
Cheers
Hakan
2016-7-8
