jaredmeakin
Hi,
Have a newely received Ronin-MX. I had to connect it to my PC to reset the password as I coldn't connect via the app. After that I balanced the Ronin-MX, calibrated it, restarted it, and then ran Auto Tune Stability. It appears to write stifness settings, but the motors never actually kick in. I've watched several video setup tutorials, and on power-on the unit is supposed to do something like this video. Mine however does nothing... when I use Auto Tune Stability I don't hear the sound of motors working.
I've reset the Ronin-MX to defaults, calibrated, and autotuned form both the PC assistant app (Windows 10) and the iOS app. Neither seem to make a difference. Is this unit DOA? I bought the Ronin-M several months back, had the same result, and ended up returning out of frustration. I'd like to get this one working, but I'm having the exact same issue as before. I've searched the forums, and this doesn't seem like an uncommon problem. However, none of those posts have a solution.
Lastly, the firmware is up to date, cables and battery have been reseated, and I've power cycled it several times.
Any help is appreciated!
