808Dave
I need some advice...did I buy a lemon Inspire pro x5? I purchased this Inspire at the end of Jan 2016 for the real estate management company I work for. I don't fly it much and have around 2hrs of actual flight time to date. Back in March I got an "ESC error" and sent it to DJI for repair. At no cost and a quick turn around they replaced:
1 - Inspire 3510 Motor-KV420 CW
1 - Inspire_DZ_EP002_V1_PCBA
When I got it back in March flew it once to make sure it was working...everything was fine. Last Thursday my boss wants to shoot some video of the 6,000 acre property (water falls, farm lands etc.). I take it home to fly it this weekend and make sure its working and I get "No image transmission signal". I search the message boards and internet for a fix...I've tried the following with no success:
- Tried 3 different Micro SD cards: SanDisk Extreme 64GB, 32GB a regular SanDisk 32GB (shows "Slow" in the display)
- Reformatted the cards in both the DJI app and my laptop.
- Uninstalled and reinstalled the DJI Go app 2 times on my Mini IPad2
- Installed the DJI Go app on my Samsung S7 android phone - (it just shows "No Signal" unlike the IPad that shows "No image transmission signal")
- I upgrade the firmware to 1.8.1.00 successful! but fails with 1.9 using any SD card.
- I examined the pins on the gimbal they are clean and not bent or broken (I hardly fly this bird so it should be good)
- I have full control of the gimbal movements and it appears to respond to the gimbal calibration and firmware update (red/green light visual cues)
- I can take pictures/video so I can assume the actual camera appears to be working...I just can't see any image on the display.
- I'm a one controller bird so I don't have another one to try.
Maybe some video controller has failed like my ESC controller did back in March. Only 2 hours of total flight time, no crashes, not even a scratch. The bird sits in its protective case (until called upon) in my temperature controlled computer room...low humidity. I would really like DJI to replace this lemon...
