Zenmuse X3/X5 Series Gimbal Mounting Bracket On custom Build
2323 9 2016-7-11
david.visagie
Flight distance : 158251 ft
South Africa
PLEASE HELP
Custom Build Quad on 6S battery
A3 + Lightbridge 2 Combo
Zenmuse X3 Gimbal and camera
2 X TB48 Intellegent Flight batteries
2 X Matrice 100 Battery Compartments
E1200 Pro Tuned Propulsion System
Tarrot T810 Retract
Question 1: How to connect X 2 DJi TB48 batterys to the A3 to be able to get full battery information on the Go app, it does say that the A3 is compatibale with DJI batterys
Question 2: what is the Input Voltage to the Zenmuse X3 Gimbal and camera via the Zenmuse X3/X5 Series Gimbal Mounting Bracket, it has a power cable but no voltage on the spec sheet.
Question 3: Does the Zenmuse X3 mounting hardware supply the LB2 with power and if not how to do this.
Thanks in advance
2016-7-11
david.visagie
South Africa
Found answer to question 2, from Matrice 600 manual, Xt30 cable from X3 Mounting kit gets connected to a port with DC-18Volts
2016-7-11
DJI-Jamie
Flight distance : 112405 ft
At this time, the device that allows an Inelligent Flight Battery connect to the standalone A3 has not been made available. We unfortunately do not have an ETA as to when it would be made available. The M100 Battery Compartments would not suffice for what you are attempting to do. Also, the Lightbridge 2 Air Component derives it power from the A3 directly via the RF port.
2016-7-11
david.visagie
South Africa
It would be really nice to have a device that will allow multiple dji flight battery's to be connected to the flight controller/lightbridge and communicate battery status to the Go App, the m600 has this feature. Anyone buying a stand alone A3 and doing a custom build would be very happy for this feature.
2016-7-22
david.visagie
South Africa
DJI-Jamie Posted at 2016-7-11 23:28
At this time, the device that allows an Inelligent Flight Battery connect to the standalone A3 has n ...
I have the LB2 plugged in to the RF port and there is no power to the LB@ no lights nothing
Juts to clarify, the RF port has 4 pins, witch I assume controls Roll, Pitch, Yaw and throttle, so how is power supplied through this cable?
2016-7-22
DJI-Jamie
david.visagie Posted at 2016-7-22 18:41
Juts t ...
Are you using the standard D-Bus cable to the LB2 air end or the D-Bus II cable? If it's the latter, do you have it seated in the proper direction?
2016-7-22
david.visagie
South Africa
Found the problem, I was using the D-Bus cable supplied with the LB2, this cable has no power, the cable supplied with the A3 controller has
2016-8-25
DJI-Jamie
david.visagie Posted at 2016-8-26 01:15
Found the problem, I was using the D-Bus cable supplied with the LB2, this cable has no power, the c ...
Good to hear you were able to get yourself up and running.
2016-8-26
Tecnocato
Puerto Rico
I want to do something similar... what are you using as the gimbal control unit? I didn't see it in your list. Am I missing something? Thanks.
2016-10-12
david.visagie
South Africa
Tecnocato Posted at 2016-10-13 00:33
I want to do something similar... what are you using as the gimbal control unit? I didn't see it in  ...
The X3 is a complete unit Camera and Gimbal, controlled by Light Bridge 2
2016-10-22
