S900 Build
951 4 2016-7-12
info.aerial-ins
Flight distance : 597487 ft
Hi,
I have recently bought an S900 which is built and has been bench tested but never flown.
It came with A2, ground station and IOSD. It had no transmitter so I have just bought the Lightbridge 2. I take it I can now remove the IOSD?
Thanks
2016-7-12
DJI-Jamie
Flight distance : 112405 ft
To clarify, do you have the iOSD Mark II or the Mini? For OSD information, you can remove it since it's redundant. If you have a Mark II, it may not be too bad to have installed as a straight CAN connection to serve as a recorder for flight data analysis (if you need it).
2016-7-12
info.aerial-ins
DJI-Jamie Posted at 2016-7-13 04:09
To clarify, do you have the iOSD Mark II or the Mini? For OSD information, you can remove it since i ...
Hi,
It's Mark II. I bought the can hub as well with the Lightbridge 2. Think I will remove it.
2016-7-12
DJI-Jamie
info.aerial-ins Posted at 2016-7-13 04:35
Hi,
Alrighty . I hope you find a new use for your iOSD Mark II.
2016-7-12
info.aerial-ins
DJI-Jamie Posted at 2016-7-13 04:45
Paper weight at the minute. Thanks for your input.
2016-7-12
