Help! 2 Problems...
948 7 2016-7-12
SAFAERIALS
Flight distance : 93146 ft
Dominican Republic
Hello,
I need some help, my Inspite needed the updates, so I have 2 problems
1-. After I updated the remote controller, I reboot it and went and power up the aircraft to switch it to landing mode, but now the remote controller is connected to the aircraft but wont respond to the command to switch to landing mode.
2- The second problem, for some reason now my sd card when I plug it to the computer I only get read mode only, so I can't put the update file in, and still the aircraft in travel mode.
Any advice will be great,
Thanks in advance
2016-7-12
Alastair
Flight distance : 96631 ft
Did you update the aircraft before the remote?  If you didn't, then that's the cause of problem #1
2016-7-12
RichJ53
Flight distance : 1837356 ft
downgrade the remote and them put the inspire into normal mode, connect the camera. Update the Inspire only first .... then redo the remote
Phantom as Inspire
#2 format the SD card in the Inspire 1 using the GO App....  this should be fine. If not the SD chip has a read only lock on it.
Rich
2016-7-12
SAFAERIALS
Dominican Republic
RichJ53 Posted at 2016-7-13 00:04
downgrade the remote and them put the inspire into normal mode, connect the camera. Update the Inspi ...
Thanks for all the videos, I'm going to try!!
2016-7-13
SAFAERIALS
Dominican Republic
Alastair Posted at 2016-7-12 20:34
Thanks! I did it the remote first, but already downgraded it and started with the aircraft and works perfect
2016-7-13
Donnie
Flight distance : 3636782 ft
Always update the aircraft first, even if the RC says it needs updating, make sure to update the aircraft first always.
Make sure you dont have the SD card or adapter "Locked " this will cause it not to be overwritten as well .
Glad you have it sorted.
donnie
2016-7-13
RichJ53
SAFAERIALS Posted at 2016-7-13 08:11
Thanks! I did it the remote first, but already downgraded it and started with the aircraft and wor ...
Good job and I am pleased you were able to update and everything works!
Rich
2016-7-13
DJI-Jamie
Flight distance : 112405 ft
SAFAERIALS Posted at 2016-7-13 23:11
Good to hear you got yourself up and running.
2016-7-14
