Inspire 1 v2.0, battery issues
1131 5 2016-7-12
arcaine25
[size=14.6667px]I purchased the inspire 1 V 2.0 around June 12th. My package had the 658B controller with the T601 bird. The battery that it came with (yeah, I know, they aren't that great, but still) the TB47, was bad. No lights, not able to charge, power on, anything at all. I sent DJI my battery for repair around June 17th or 18th (I can verify later), and literally, finally after almost a month, and just about 5 minutes ago I received it from UPS. Not in a battery box (retail), and apparently not a replacement battery either (haven't verified serial numbers, but will) It was just put in the shipping box and covered with brown packing paper. I pull it out of the box, pres the power button.. it flashes the one light indicating low charge.. I connect it to the charger to charge it thinking all is good, and the light flashes twice, then goes off and doesn't charge. Tried 2 other charges for Inspire (all DJI chargers btw), same thing. this battery is absolutely JUNK JUNK JUNK! In 2 months I received a bad Phantom 4 battery (identical issue to the Inspire) the bad Inspire battery, and today the bad replacement battery and a bad Phantom 3 battery. DJI has just about been written off of my book. This is stupid and just plain lazy.
2016-7-12
DJI-Paladin
Flight distance : 2408 ft
Sorry for your experience, arcaine25. Could you provide me with your RMA number here? Thank you.
2016-7-12
arcaine25
DJI-Paladin Posted at 2016-7-13 01:56
my RMA number is 0617201628207309252PS
2016-7-13
DJI-Paladin
arcaine25 Posted at 2016-7-13 18:26
Thanks for your feedback. We will look into your case.
2016-7-13
arcaine25
DJI-Paladin Posted at 2016-7-13 05:29
Thank you. And just an FYI, I did try as mentioned above multiple chargers, I tried the short press long press method while connected to the charger, and still nothing. Also, I just verified, this is not the same battery that I sent in to be repaired. the Serial number and QR code on the bottom are completely different, indicating a replacement battery that I would have thought would have been tested first? Also, concerning to me is the fact it was literally placed in a box, and covered with only brown paper and not in its original foam packaged retail type enclosure.
2016-7-13
DJI-Paladin
arcaine25 Posted at 2016-7-13 18:39
Thank you. And just an FYI, I did try as mentioned above multiple chargers, I tried the short pres ...
Sorry for my delay.Our tech support has escalated this case. Hopefully it could be solved soon.
2016-7-14
