Viper989
Flight distance : 891194 ft
Hi all ,
My first problem with my P3P since i bought it in May 2015 .
I have 5 batteries , including a brand new one .
I went out to test the latest firware today with all batteries fully charged from this morning
Slapped in the new battery to give it an easy first run . Since i kept the Bin on the card , it upgraded the battery . Went out , brought it back at 50% .
Slapped in another battery to test litchi , again updated the second battery . All went fine .
Slapped in third battery. Tried to update , did the DUH-DUH-DUH but failed with a non-stup DUH that went on for like 2-3 minutes . Tried to shut it down with no luck . Funny thing i noticed is the battery had 2 lights on at that time , the 2 middle ones . After trying a coule of time to turn it off , i finally removed it. Then , no lights at all , even when pushing the on/off button .
Slapped in a fourth battery , it updated itself . Went out for testing again . Wow a personnal best of 2.2 Km without a single drop in video . Had to turn around as the GEO told me i was close to an airport ( Which was true )
Slapped in last battery , appears it did not need an update.
Came home and tried to charge the third battery , no luck , nothing .
Any of you experienced some thing like this with one fo your battery ? If so , did you saved it and how . Is there a way to reset a battery to factory default .
many thanks guys
