Cetaman
Flight distance : 2528264 ft
Aloha user4fb61a1fc3,
You have the same rig as my P3P and P4. On both controllers, I used a dremel tool to widen the middle of the notch that is in the middle of the bottom of the holder. Works like a champ and have had no problems at all. It actually seems to hold the tab better when I plug in and pull out to charge the tablet.
Because I have two controllers and one tablet and the fit is very tight, I put painter's tape (glue not too sticky) over the rubber foam supports so it will slide in and out better. That works great to. But, I got my P3P first and the rubber foam is a little chewed up, so do it from the beginning so as not to damage the foam rubber. The slightly sticky painter's tape works well and does not pull on the foam when you replace it.
Aloha and Drone On! |
