X5 dropping frames
1170 5 2016-7-14
rj74
I'm having some frame drops on X5.
Is there any way to fix?
Thanks
2016-7-14
flighttime1
Flight distance : 906352 ft
I've found the frame dropping a bit of a mystery. Maybe your experience and mine can help resolve it. I spent a whole day shooting a soccer tourney and had zero frame drops in over an hour of footage. I shot some indoor footage and had frame drops on almost every clip. Both were shot 4K and 24 fps. I'm using a Samsung EVO+ SD card. Logic says the only difference is that one was relatively low light but I can't imagine how that would ever cause frame drops. I've decided to get a faster SD card to see if that helps but would be interested if what your experience is. Are you always having the problem or under what conditions?
2016-7-14
DJI-H.C
Flight distance : 13602 ft
Hi, can you upload a video to dropbox/Google Drive for us to analyze? Thank you.
2016-7-14
rj74
flighttime1 Posted at 2016-7-15 05:28
I've found the frame dropping a bit of a mystery. Maybe your experience and mine can help resolve it ...
Yes, I also find lower light drops more frames. I use the Lexar 1000x, but the card doesn't seem to make a difference, same performance with supplied Lexar 633x card
2016-7-15
flighttime1
DJI-H.C Posted at 2016-7-15 00:10
What addy do I share with on Google Drive?
2016-7-15
Utahn
flighttime1 Posted at 2016-7-15 14:04
Would you please put the address here?  If the video doesn't involve much privacy content.
2016-7-17
