X3 Repair?
876 4 2016-7-14
naildrivingman
Flight distance : 112451 ft
I have a damaged X3 as follows:
1. Broken main arm
2. Torn ribbon cable
3. Scratched lens
Has anyone sent the camera only in to have repairs done?  If so, did DJI want the whole kit (bird, RC, etc)?  What were the damages and costs?
I bought another camera and am able to fly, but I think a backup camera is not a bad idea.
Any thoughts/experience would be helpful.
Thanks,
Chris
2016-7-14
DJI-Jamie
Flight distance : 112405 ft
Does your replacement camera work with your aircraft without any issue? If the aircraft works fine, then you could just send in the camera. Unfortunately I would not be able to provide a quote, as it would need to be evaluated by a repair technician when it's sent in. They would send you an invoice prior to performing any repairs, so you can choose to opt out if you don't want to pay their amount.
2016-7-14
naildrivingman
DJI-Jamie Posted at 2016-7-14 12:51
Does your replacement camera work with your aircraft without any issue? If the aircraft works fine,  ...
Thanks Jamie.  Yes the replacement does work with the bird.
I was thinking that with the advent of the new camera(s), the cost of repair may be well spent elsewhere.  I will consider my options.
Regards,
Chris
2016-7-14
datincan
Flight distance : 144649 ft
naildrivingman@ Posted at 2016-7-14 20:33
I was thinking that with the advent of ...
USdrone repair , Jermy works miracles on gimbal repairs and is always cheeper than dji. http://www.usdronerepair.com he will probably give you an estimate by email if you send photos and explain.
2016-7-14
naildrivingman
datincan Posted at 2016-7-14 17:36
USdrone repair , Jermy works miracles on gimbal repairs and is always cheeper than dji. http://www ...
Thanks for the tip.  I will contact him.  My guess is that it might even be quicker than shipping to China.
Best Regards,
Chris
2016-7-15
