ricci2
Flight distance : 61158 ft
hello,
Has the M100 an hdmi in, because if so you could mount a GoPro or similar on an aftermarket gimbal? The M600 has Lb2 aux hdmi so the onboard camera is used as navigation and the 2nd camera is the skyward facing device. Even if the camera was mounted via vibration mount and no gimbal you could just use the M100 to track a visual course, With a 4k camera and a wide angle lens you could capture high def visuals.
I know it can be done because I use a thermal camera to do overhead video of structures. Also on the M600 I extended the x5 camera mounting platform as far forward as it would go and pointed the x5 up as far as it will go, about 45º above the horizon and filmed with some of the props in the view, I had to plan the shots and zoomed in, but it worked. I bought an osmo handle, gutted the electronics out and use the pro mount to attach to the top of the craft, I know the pinouts for the x5 so just connected to the hdmi in on the lb2. This worked fine until it fell off one day due to me not tightening the clamp down enough, cost me a new lens. You would have to be confident in the electronics side but it again worked using AE lock but focusing was a pain with the app going out of range but I managed 50m line of sight. I think I buggered up the warranty though. As you might of gathered I do a lot of experimenting and sometimes it works and sometimes not.
Ricci |
