What is these numbers ?
496 4 2016-7-15
SectorDrone
Flight distance : 1114649 ft
After the new FW update..
I had cal the IMU.
There's accelerator and Gyros,  when bird is at rest, are the ideal and your numbers on these fields?
Thanks
2016-7-15
DJI-Jamie
Flight distance : 112405 ft
Could you clarify which Phantom model you have?
2016-7-15
SectorDrone
P4..
and is it OK to cal the IMU on level but metalic surface that causing compass error ? does it affect the IMU cal ?
My numbers are .001 and .004 at Accelerator and 0.001 and .002 at gyroscope..are those numbers good.
2016-7-15
labroides
Flight distance : 9991457 ft
SectorDrone Posted at 2016-7-16 15:31
P4..
and is it OK to cal the IMU on level but metalic surface that causing compass error ? does it  ...
Calibrating the IMU indoors with steel nearby is no problem.
It's the compass that you have to be careful with.
2016-7-15
DJI-Paladin
Flight distance : 2408 ft
SectorDrone Posted at 2016-7-16 13:31
P4..
If the bars are green, it means it is in good status and you don't need to worry about them.
2016-7-15
