Cetaman
Flight distance : 2528264 ft
Aloha fpezzulo,
While you are figuring out the settings, look for the video settings that allow you to record at 1080p or 2K, maybe higher depending on your Phantom model. The higher resolutions make for smoother pans and generally nicer quality all around. Check out your frame rate. 30 frames per second and higher also help with smooth pans.
Along with the previous comments, this is good for an early video. Keep practicing, it will get better and then there is the fun of just flying!
Aloha and Drone On! |
