RC ASSISTANT
8058 5 2016-7-17
jeselectrical
My Phantom Vision has not been out for a year due to ill health dusted it down today updated the firmware on the Drone all good. I have  gone to RC Assistant to update and calibrate remote control and it will not connect to controller. Been to Dji downloads and it seems vision +2 is not supported telling me to go to Vison 4 .Anyone got a link to the latest Rc assistant software please ?
2016-7-17
johnwarr
Flight distance : 6467 ft
What version of the RC assistant do you have ?
There have not been any new versions since 2014.
If you have RC Assistant V1.2 then you have the latest.
As usual, much more detail is needed on how you are trying to connect and what hardware you have.
2016-7-17
AssHatModerator
You're trying to go here?  http://www.dji.com/product/phantom-2-vision/info#downloads
Just do a mouse click on that pop up window and it should disappear.  You'll then be able to download any of the software you need.
2016-7-17
jeselectrical
AssHatModerator Posted at 2016-7-17 23:21
Just do a mou ...
Thanks for that. I am  using V1.2  on Windows 10 and other pc XP Tried this on 3 pc now no luck
The version is the same as I was using last year I have downloaded drivers and installed first then V1.2 clean install.  Loged in but RC will not recognise the controller any ideas please ?
2016-7-21
jeselectrical
Just do a mou ...
Great thanks
2016-7-21
Northofthe49th
jeselectric
not sure for the phantom vision however for the vision plus v3.0 the RC can also be calibrated if on while you are connected to the Vision assistant calibrating your phantom
2016-7-23
