MD_Icarus
I think GPS is used to maintain the horizontal position at any altitude. You can see the difference as soon as you go into ATTI mode, even when you fly 3 feet over the ground, it starts drifting with the wind. (GPS is off).
I am not sure if DJI uses differential correction using the user's device which is at the ground, but even with no such correction, it can be accurate to within a few feet, assuming you have a large number of satellites (the more satellites, the less error).
I think it uses GPS to maintain horizontal position during landing, and the VPS is used to control vertical position. |
