Offline Maps unavailable - Android
791 8 2016-7-21
richbarksby
Flight distance : 642559 ft
Hello
Just finding my way with the P4 and wanted to know how I cache or download satelite maps (Google) whilst off line and out flying?
Tried on line moving around then disconnecting and then all map data is lost (apart from basic Google standard map)
All location services are on - Nexus 7 v2
Thanks
2016-7-21
labroides
Flight distance : 9991457 ft
If you don't have maps it should be no big deal.
I've flown the P3 since it was released and only used maps once.
But the normal way to cache maps is to open the DJI app at home with your tablet connected to wifi.
Go to camera view and open the map window.
Find the area you are interested in at the scale you want and pan around all over the area.
That should be it.
2016-7-21
DJI-Paladin
Flight distance : 2408 ft
Hello richbarksby, you may need to cache the map with Wifi service before your flight. Zoom in and move the map in the camera view and the map will be automatically cached.
2016-7-21
DJI-H.C
Flight distance : 13602 ft
Hi, in Google map on your Nexus 7, you need to turn on the option to cache map.  At home with wifi connected, then you zoom in and zoom on the place you intend to fly, it should be cached then.
Disconnect the wifi and see if the details of the map are preserved.
2016-7-21
richbarksby
Hi guys
Tried all above and didnt work out in the field. Do I need to leave tablet switched on up until point of flight?
2016-7-25
DJI-Ken
Flight distance : 1515312 ft
richbarksby@gma Posted at 2016-7-25 23:35
Hi guys
Tried all above and didnt work out in the field. Do I need to leave tablet switched on up u ...
Don't know why it's not working for you.
After you get the map zoomed in your flying area then close the GO app and the map should be there when you get to your flying area.
2016-7-25
mjanzou
Flight distance : 14820 ft
Sounds like a bug perhaps?
2016-7-25
thorsten.yachtc
Flight distance : 287884 ft
China
Why u don't give th option to change the source of map ( Goggel or Here or baidou ...)  it's a bit pain in the ass th ave a Germangalaxy s5 with Googel maps and lib in China. I installed Here and Baidou..but I can't use.
Just give during installation of the App the change to choose. Its not so hard to do..
2016-7-25
Geebax
thorsten.yachtc Posted at 2016-7-26 11:30
Why u don't give th option to change the source of map ( Goggel or Here or baidou ...)  it's a bit p ...
'It is not so hard to do.'
On the contrary, it is not easy to do either. In order to use any maps the application developer has to pay a licence fee to the map provider, and then you have to use the map provider's SDK to implement the maps.
2016-7-25
