Matt-and-Riley
Flight distance : 324442 ft
I've pulled and tugged on the car mount, to the point of almost breaking the window, it seems really strong. But ... the window or panel has to be really flat. Even slight curves usually means one sucker not sticking properly. Also try to have 2 suckers at the top as it will want to pivot on the bottom one, if you have 1 at the top it's more likely to pop off. On my car I can only find 3 places flat enough for a good grip, none are based on the shot I may want, simply where it will stick properly. Quite limiting really.
I've tried a strap in case it falls off, but I think this will probably cause more damage to the camera and car, the osmo will be flapping around bouncing off your car till you can stop. |
