Can't fly higher than 167 feet! No beginner mode
1366 6 2016-7-21
colin_mc_lean
I'm having issues in ATTI mode (I haven't tried GPS mode yet) where it won't let me go higher than 167 feet.  I DO NOT have beginner mode on, so I'm not sure why it's limiting my height.  Any ideas/suggestions?  I'm assuming there's another setting somewhere that I'm overlooking?
Thanks!
2016-7-21
DJI-Jamie
Flight distance : 112405 ft
Could you clarify what firmware version you're currently on?
2016-7-21
DJI-Paladin
Flight distance : 2408 ft
Hello colin_mc_lean, the limited altitude of beginner mode is 30 meters. Did the drone record a home point at the beginning? You can post a screenshot of this flight record here.
2016-7-21
NEP_I1RAW
DJI-Jamie Posted at 2016-7-22 13:01
I'm on the most recent firmware, 1.09.01.30.  One thing I haven't done yet though is an IMU calibration (forgot to do so after firmware update).  Maybe this will help, I'll report back when I get the chance.
2016-7-22
NEP_I1RAW
DJI-Paladin Posted at 2016-7-21 23:44
Hello colin_mc_lean, the limited altitude of beginner mode is 30 meters. Did the drone record a home ...
I don't think it recorded a home location, but I'll double check and get back to you.
2016-7-22
DJI-Paladin
NEP_I1RAW Posted at 2016-7-22 22:43
If it doesn't record a homepoint, the altitude will be limited to 50 meters. You can check this flight when you reach the flight record page.
2016-7-24
NEP_I1RAW
DJI-Paladin Posted at 2016-7-25 10:39
If it doesn't record a homepoint, the altitude will be limited to 50 meters. You can check this fl ...
That definitely makes sense.  I was deep in some woods and only had a couple satellite signals.  I checked the flight data and it did not record a homepoint.  Thanks for everyones help!  I've flown it since (with homepoints recorded and it works just fine flying high).
2016-7-25
