EranR
Flight distance : 297497 ft
Israel
Hi,
For some time now I've been having an issue with my P3A. Some, but not all of the times, when I power it up I get no video feed. I can shoot stills and video, control the gimbal, everything else works.
I can solve it by powering off and on, but sometimes I need to do it more than once. Also, switching between PAL and NTSC resets the camera and the feed usually starts showing. Sometimes more than one reset is needed.
This issue happens with the DJI GO app and also with my own app. When checking with my app I can see that video packets are received from the aircraft, but in an irregular way. The video decoder cannot decode them to create an image. Also, when reseting by toggling PAL/NTSC I sometimes get 'Camera error code 01' message through the SDK's DJIDiagnostics.
Of course, the aircraft is in perfect condition and has not been through any crashes or bad landings.After the video starts showing it keep going throughout the flight. Never had issues during flight. Even when going out of range and losing feed, it comes back when I get back in range.
All the tests I have done seem to indicate it's not a hardware problem, but I could be wrong. I am not sure, but I think the issue began after one of the firmware upgrades. Not sure which and even if related.
Is there anyone with this issue as well?
Any ideas anyone?
Thanks,
Eran
