Active Braking is very aggressive
jafarini
Flight distance : 15252589 ft
Georgia
Hi folks
I noticed that after one of the firmware update the active braking became extremely aggressive on Phantom 3 (ADV/PRO).
I also managed to have my Phantom crashed. It was overturned during braking.
Have more than 400 flights and I think I did nothing unusual. The wind was also not strong.
Now after buying another P3 I still notice that active braking is very aggressive on this machine as well.
It is so aggressive that I afraid to release the knob immediately when moving forward. I always try slowing down very carefully.
From DJI GO I decreased the braking power to 80 but it is still not normal compared to what I remember it was 1 year ago.
Is it just me or do you notice this thing happen? Maximum braking power is 120 on the GO app but I cannot imagine what it could be and why DJI puts it here.
When I bought new P3 I use the same old controller. Could it be problem? I tried to recalibrate the controller.
Thanks for the comments and suggestions beforehead.
2016-7-22
Not A Speck Of
Flight distance : 666493 ft
Could you elaborate on "overturned during braking"?
Did it turn upside down in the air and then fall to the ground?
I notice breaking get more aggressive at one point, but I also remember that before that, it used to coast. That is, you could let up on the throttle and it would still travel for a good distance after that.
I can imagine a scenario where people would stop flying by letting go of the throttle at some point short of an object, then see the craft continue on and hit the object. If this happened enough times and people complained to DJI, they might adjust the default breaking behavior. But it should still be adjustable to return to the previous behavior.
Have you tried a number under 80?
2016-7-22
DJI-Ken
Flight distance : 1515312 ft
Can you please post a video showing how aggressive it is braking?
Since you have it turned down all the way it should not be a hard stop.
Also, you said your old Phantom crashed from braking as it braked so hard that it went inverted.
That cannot happen and you sent the flight records in to be evaluated correct?
Pleas sync your flight record and star that flight as a favorite and provide the date and youe DJI login email and I would like to review that flight.
After you post a video of the violent braking you currently are experiencing then I will tell you if that is normal or if you should send the aircraft in.
2016-7-22
JAFARINI
Georgia
DJI-Ken Posted at 2016-7-22 07:55
Hi Ken
Thanks for the message.
The log is synchronized Flight date is 22.05.2016 (4th flight) Distance 25.3m
Unfortunately the drone is dead I cannot fly with it anymore otherwise I will be recording the video. After this accident it is falling very often without any reason.
2017-1-5
DJI-Ken
JAFARINI Posted at 2017-1-5 02:04
Hi Ken
Your last post was almost 6 months ago. What is your email and I will review the last flight.
2017-1-5
JAFARINI
Georgia
DJI-Ken Posted at 2017-1-5 07:41
my email is: jafarini@gmail.com
Incident with active braking was this flight: Flight date is 22.05.2016 (4th flight) Distance 25.3m
Thanks
2017-1-6
