mydogisdead
Flight distance : 8250568 ft
Thanks Rich, The trick is to keep it in the middle and allow it to follow at a similar speed The up and down moment can be adjusted but go really slow for this as the left thumb dial takes some getting used to...
The right control stick is mostly used to match your subjects velocity and to go near or far from the subject...
I recommend this for long straight chases... and twist and turns of the subject, let the camera follow at a distance... Oh and your yaw control iis your panning so be real slow with this control or max out the exponetial values in your controller.
There is a advance camera tracking software called autopilot, this uses gps to track the subject but you need a phone to do this... maybe one day I might be able to demo this on a subject... |
