Battery firmware???
954 6 2016-7-22
Karatekid18000
Hi guys, I have a quick question. I have an old p3 battery that was updated to my old p3p (firmware 1.8.60).  I have a new p3p with an older firmware 1.4.1+ , will this cause a problem assuming that I don't want to upgrade the new drone?
2016-7-22
DJI-Ken
Flight distance : 1515312 ft
If there is a battery update then the app will tell you.
1.9 and 1.6 have battery firmware updates.
Since you are wanting to stay on 1.4 with your new aircraft and the battery has the 1.6 update I'd have to recommend being on the latest update.
Is there a reason you want to stay on 1.4?
I've updated over 20 Phantoms and have not experienced any issues.
2016-7-22
Karatekid18000
Thanks for the answer, first, the firmware is 1.4.1+ which I believe is equivalent to 1.5.x
The reason I want to stay on this firmware is because the drone is flying prefect, no problem what so ever. In the past, firmware update used to reduce my flight stability, so what is not broken don't need fixing.
Do you believe it would cause any problems using that battery?
2016-7-22
DJI-Ken
Karatekid18000 Posted at 2016-7-23 01:45
The reas ...
All I can say is it's recommended to be on the latest update of everything.
I did forward your thread to headquarters where they may be able to give you a better answer.
2016-7-22
Karatekid18000
Ok great, I hope they will post here their opinion
2016-7-22
DJI-Paladin
Flight distance : 2408 ft
Karatekid18000 Posted at 2016-7-23 11:02
Our Field Applications Engineer tells me that such kind of situation may lead to some problems. So it is recommended to keep all the firmware up to date to ensure the user experience.
2016-7-24
PoppaHotel
Flight distance : 39600 ft
DJI-Paladin Posted at 2016-7-24 20:52
How do I upgrade spare batteries?  Battery in drone at time of upgrade was upgraded.  Other batteries when inserted indicated upgrade need and "battery broken" send in for repair.  New device and battery, never been flown.  How to I upgrade spare batteries after drone and RC has been successfully upgraded?
Consideration appreciated.
2016-12-12
