X5 no video feed on Osmo or I1
1483 5 2016-7-22
TravisSRT
Flight distance : 68555177 ft
Hello, I have an Inspire 1 Pro, two standard Inspires and an Osmo. I purchased a second X5 camera and X5 adapter to use on my Osmo only.  Today I stuck the new X5 on the Osmo and it said firmware update required.  I downloaded the latest firmware from DJI.com and put it on the SD card and started the update.  A few minutes into the update the left hand LED turned red and it beeped constantly.  I saw on the app that the update failed.  I now get no video feed from the camera when connected to the Osmo or Inspire 1 Pro.  It will not complete an upgrade using the Osmo or I1.  My other X5 works fine on both so I think I can rule out hardware on the I1 and Osmo/X5 adapter front.  I called DJI Support US and the guy sounded like he was reading a script and was no help at all.  I tried the Trigger + Record + Power firmare reset with no success.  Any suggestions before I send the camera back to the vendor I purchased it from?  Oh, In the app it shows that it's on the latest firmware for both Osmo and I1..
2016-7-22
DJI-H.C
Flight distance : 13602 ft
It sounds like the X5 you bought is defective and may need to return it.
2016-7-25
liammucklow
Any update here?
I have the same problem
2016-9-15
majed.side
Me too .
I need solution please .
2016-9-15
DJI-Thor
liammucklow Posted at 2016-9-16 10:42
Any update here?
If you updated the firmware, and tried a different phone, still have no image transmission, it is a hardware issue and needs to be returned. Thank you.
2016-9-15
MajedHD
DJI-Thor Posted at 2016-9-16 12:29
If you updated the firmware, and tried a different phone, still have no image transmission, it is  ...
Thanks for your feed pack
2016-9-15
