Fly Dawg
If your S5 is running Android Marshmallow (6.0.1) then that, I can pretty much assure you is the
issue. You can not have both DJI Go and Litchi installed on the device. Either one should work fine
by itself, but neither will connect if both are installed. I have the same issue on my S5 and it is indeed
an issue with Marshmallow. Lollipop will work just fine with both, which is probably why your S4 works. |
