Phantom 3 Standard no signal, goes limp, camera LED not working
rivest266
Flight distance : 131604 ft
upon powering up the aircraft, there is no green light on the gimbal, no video signal to the app, and the gimbal goes limp about 25 seconds after power on.
This aircraft has flown about 75 times.
2016-7-24
cloudycante
Flight distance : 558173 ft
Wouldn't know what to do, frankly. Have you tried resetting IMU and gimbal from the App? Hopefully a DJI rep will have some straight answer for this behavior.
2016-7-24
DJI-H.C
Flight distance : 13602 ft
Hi, when you start the drone, what does it say on DJI GO?  Can you post a screenshot? Thank you.
2016-7-24
OrlyP
Flight distance : 36916 ft
Philippines
Very familiar behavior. I encountered something similar when my last firmware update failed on me and I had to shutdown and restart the aircraft. After that, the gimbal went limp. I restarted and eventually completed the firmware upgrade. After which, everything went back to normal.
2016-7-24
fansf00ed097
Was sent back and replaced 5 weeks later. Camera and parts of the shell were replaced. Now flying fine.
2016-12-5
fans411403ee
Singapore
fansf00ed097 Posted at 2016-12-6 09:12
hi there, just asking.. how much you were quoted to replace the camera? i got the similar problem as yours. thanks in advance for your reply.
2016-12-9
fansf00ed097
I wasn't charged anything, still under warranty at the time. Still flying fine, but not being used as often due to the winter up here in Montreal.
2016-12-12
djiuser_kNTSZNeWmDVy
Trinidad and Tobago
P3 pro dead humble and led....so no video
2019-2-1
