Camera Control on 2+
799 4 2016-7-24
daveford1
When I power on camera goes nuts..
Swinging wildly around and severo heat up very quickly..
I replaces the flex conductor tape but to no avail..
I took drone apart and checked connectors.. All appear to be OK..
Anybody have any theories???
2016-7-24
Bilzc10
Flight distance : 351575 ft
what do you mean by freaking out?
something like this?:
The gimbal looks like it wants to end itself!
2016-7-24
raym
Flight distance : 53819 ft
I had this problem it went away ?
2016-7-24
DJI-Paladin
Flight distance : 2408 ft
Hello daveford1, have you tried to calibrate the IMU? A piece of video would be appreciated.
2016-7-25
quanthonytrang
Flight distance : 419980 ft
Your gimbal is scared of heights.
On a serious note... check the hidden hex head grub screw at the top of the yaw arm. Its on the opposite side of the flex cable. Tighten this to the flat side of the D shaft. It may of come loose from a couple of bump landings.
2016-7-25
