FPV Litchi v DJI GO
skipilot1
Flight distance : 1557398 ft
I have been playing around with Litchi in FPV mode to see how it compares to the DJI app. I believe that with Litchi I get better RC signal but the video seems to die out sooner.
The other problem with Litchi is the RTH function. If the RC and drone lose contact the auto RTH kicks in. The problem is when the connection is re-established and I want to fly manually.  A message in a white box in the center of the screen tells me the drone wants to use RTH mode. The only option is to hit "Go Home Now" which triggers the RTH. There is no other option and I have no way of getting the white message box off the middle of the screen so FPV flying becomes useless at that point.
Help!!
2016-7-27
DJI-Ken
Flight distance : 1515312 ft
The RC signal would be the same with both apps. I've never used anything other than the GO app so I can speak too much about 3rd party apps.
2016-7-27
OrlyP
Flight distance : 36916 ft
Philippines
Have you tried cycling the S1 switch to cancel the RTH and regain control of the aircraft?
2016-7-27
skipilot1
OrlyP Posted at 2016-7-28 10:19
It is a P3P and it was in P mode so there is nothing to switch.
2016-7-27
Rnfaust
Flight distance : 734938 ft
Have you tried tapping the RTH button on the RC?
You could start the RTH procedure and immediately cancel it by tapping the RTH button.
2016-7-27
skipilot1
Rnfaust Posted at 2016-7-28 11:08
You could start the RTH procedure and immediately c ...
Yes, and the message still comes up.
2016-7-27
