M100 and controller connection
1881 9 2016-7-28
userdbab24a359
Belgium
Hi,
I can't connect the my M100 with the remote controller. I follow the procedur of the user manual but when I hit "Linking RC" I obtain the following popup:
popup
popup
On the web I found that it there should be a "decline" and "agree"button. When I hit "ok" nothing happens.
Any idea why ?
Thank you.
2016-7-28
DJI-Jamie
Flight distance : 112405 ft
It doesn't look like you have any connection to the aircraft in order to bind through the app. Try the following to manually bind the RC to the aircraft:
- Turn on both the aircraft and the controller.
- Press C1, C2, and the record button on the controller, then the controller will beep like D-DD.
- Let go all fingers, press the wheel on the right side of the controller and then the first light of the controller will become blue and it will constantly beep DDDD.
- Use a pen to click the linking button on the aircraft and hold for 3-5 seconds, and then take the pen off the aircraft and wait, it will be linked soon.
To clarify, is this a single operator unit or a dual operator. Did you switch out the RC recently?
2016-7-28
userdbab24a359
Belgium
DJI-Jamie Posted at 2016-7-28 17:34
It doesn't look like you have any connection to the aircraft in order to bind through the app. Try t ...
Thank you for your reply.
This is a single unit operator and I didn't switch out the RC. I tried your procedure with success: the aircraft LED is flashing yellow slowly and the RC LED is a solid green. However I can't launch the simulator due to bad connection see picture. Any idea why ?
2016-7-29
DJI-Jamie
userdbab24a359 Posted at 2016-7-29 16:37
This is a single unit operator and I didn't switch out the RC. I tried  ...
Can you clarify if you are able to get into normal camera view? Is all the firmware up to date on the aircraft?
2016-7-29
userdbab24a359
Belgium
DJI-Jamie Posted at 2016-7-29 16:11
Can you clarify if you are able to get into normal camera view? Is all the firmware up to date on  ...
Yes I can get into normal camera view and the firmware is up to date. I tried earlier the simulator on the Iphone of a colleague and it worked perfectly. This leads me to think that the problem comes from the DJI Go app on my phone. For information this is an Android 6.0.
2016-7-29
DJI-Jamie
userdbab24a359 Posted at 2016-7-30 00:14
Yes I can get into normal camera view and the firmware is up to date. I tried earlier the simulato ...
To clarify, what version of the DJI Go app are you using? What mobile device do you have? Have you tried uninstalling and reinstalling the app to ensure that all necessary permissions were allowed?
2016-7-29
userdbab24a359
Belgium
DJI-Jamie Posted at 2016-7-29 22:27
To clarify, what version of the DJI Go app are you using? What mobile device do you have? Have you  ...
I have a vernee thor under Android 6, the version of DJI Go is 2.8.3 and yes all the permission are being granted.
2016-8-1
DJI-Jamie
userdbab24a359 Posted at 2016-8-1 18:04
I have a vernee thor under Android 6, the version of DJI Go is 2.8.3 and yes all the permission ar ...
Do you have USB Debugging enabled? This issue is most likely caused by either a setting on the phone or a compatibility with said device, as I'm able to connect a LG G4 to the M100 and can access the Simulator.
2016-8-1
sami.mezhoud
Belgium
DJI-Jamie Posted at 2016-8-1 17:13
Do you have USB Debugging enabled? This issue is most likely caused by either a setting on the pho ...
Problem solved !
The USB Debugging wasn't enabled.
Thank you.
2016-8-4
DJI-Jamie
sami.mezhoud Posted at 2016-8-4 20:38
Problem solved !
Good to hear! Thank you for the update.
2016-8-4
