Drone and Battery Storage in a Hot Car
8997 16 2016-7-28
capt_mats_tache
Are there any issues with leaving the P4 or its batteries in a hot car?
2016-7-28
dak162
Flight distance : 2999472 ft
The issue with LiPo batteries at extreme temperatures are most notable when the battery is in a low voltage state, i.e discharged to 0-10%. In these cases there is evidence that the voltage capacity will rarely, if ever recover.  When the are maintained charged (ideally between 50-60% charge), extreme temperatures will affect the battery (voltage drops when heated, rises when cooled) but the battery normally rebounds when returned to ambient temperature.
When flying close to the limits specified by DJI (manufacturer) during extreme temperatures, keep in mind voltage is dropping and may drop rapidly depending on current draw. This could lead to a crashed aircraft and an irrecoverable battery.
To answer your question, try to keep the batteries between the manufacturers suggested temperatures and remember it is a bad idea to fly with a hot or cold LiPo battery.
Hope this rambling helps.
This link will give you an idea about the behavior of LiPo batteries in extreme temperatures.
Boiling Batteries
2016-7-28
DJI-Ken
Flight distance : 1515312 ft
I would not leave the batteries in a hot car. It can get 150 degrees in there and I'm sure if left for hours on end is not good for the batteries.
https://dl.djicdn.com/downloads/phantom_4/en/Phantom_4_Intelligent_Flight_Battery_Safety_Guidelines_en.pdf
2016-7-28
UCLABruins
Flight distance : 488904 ft
This question might as well be "Are Lipo batteries dangerous leaving in a hot car"?
My feeling is that if you are 100% sure that the inside of the car won't go over 90 degrees F, it should be okay......
I have had a lipo battery burst into flames at 2am in the moring from just sitting there......it was a bad lipo
Basically, do you want to risk it.
If you insist on leaving it inside the car, put the lipo in a container.
2016-7-28
capt_mats_tache
Thanks for all the input I just don't want to miss opportunities to get footage.
2016-7-28
thorsten.yachtc
Flight distance : 287884 ft
China
So what do do.. I live on a island in china. We always have 28 to 32 degree centergade.Afte a normal flight with my p4 the batteries are really!!! Hot. Up to 51 degree centergrade.
I like to see a statement of DJI.
Thx.
2016-7-28
DJI-Paladin
Flight distance : 2408 ft
thorsten.yachtc Posted at 2016-7-29 10:01
So what do do.. I live on a island in china. We always have 28 to 32 degree centergade.Afte a normal ...
Place the battery in a cool place after a normal flight. When the battery meet its heat threshold during the flight, the app will prompt a notification of it. But I'd suggest you to keep your eyes on the battery temperature during the flight and land the drone when the battery reaches 60°C.
2016-7-28
DJI-H.C
Flight distance : 13602 ft
Don't leave your drone batteries in the car unattended. In summer time, the temperature in the car can get as high as 170 F, or 76 C, and it will kill your battery.
This happened to a forum member several days ago. I can't find the post..
2016-7-29
Hilda
Colombia
It is not safe to leave the battery in the car. Everyday there are a lot of accidents occurring due to these king of carelessness. It is advisable to store the batteries in storage space like http://www.ultrastor.ca/storage- ... rm-storage-options/ instead of storing them in open space like car, especially hot car. I have read many articles which mentions the fire accidents caused by batteries. So be cautious and try to store them separately.
2016-11-22
PilotRyan
Mauritius
okay battery cannot be stored in Hot Car. But let say i'm at work i wish to fly in the afternoon and i don't want to bring the big drone case at work. Can I just remove all the battery and just leave the drone and the controller inside the car on a hot summer day?
2018-2-14
RedHotPoker
Flight distance : 165105 ft
You could use a Coleman cooler, for keeping it cool, in the car.
Works the opposite of a thermos. ;-)
RedHotPoker
2018-2-14
solentlife
Flight distance : 1087530 ft
Latvia
Hot cars and batterys are a No NO .... that includes the battery in your controller.
The AC (drone) itself is fine ... would take a lot of heat to affect that.
But any battery - better to not leave it in there.
Think on this : Dogs die in hot cars ... even with a window cracked open. If a Dog can die in there - what do you think it does to your $150 battery ??
You can forget the cooler - unless you cool it way down before and don't leave it too long in the car to slowly heat up ...
Nigel
2018-2-15
RedHotPoker
Unless you cool it first. What a dork. Yes they normally hold cold packs or ice. Hahaha
Leave it to you to try and be the soothe sayer. You are a headache.
What do you think, fill the thing with hot coals first?
Is that the very best you can do, to be determined to undermine what ever I Post. Sucker man. You would be in PC.
Please stop including me in your evil thoughts, devil made you do it...
RedHotPoker
2018-2-15
solentlife
Latvia
I missed the word Coleman ... which I assume you mean the DC powered Cooler box - that is fine - if you don't mind your car battery being drained.If you mean just a plain insulated box - suggest you check how long they stay cool.
I have two DC powered cooler boxes ... Minutemaid - that draws over 10A ... the other draws just under 5A .....
I also have 1 Cool box and 3 Cool bags - all plain insulated variety - best is maybe an hour or two at most if not opened ... even with Freezer packs in - they will not survive a day. And if you do NOT cool the box first - then your freezer packs will last significantly less ...
RHP - suggest you consider anger management.
Of course having got fed up with you - you are reported AGAIN ...
Nigel
2018-2-15
RedHotPoker
solentlife Posted at 2018-2-15 01:23
Like I said, just a bunch of dopes. Pathetic losers.
https://www.vox.com/2018/2/19/17 ... pics-doping-curling
Russian Olympic doping in Curling. Hahaha
RedHotPoker
2018-2-19
Imovetheearth
DJI-H.C Posted at 2016-7-29 01:43
This is an idea I want to try but haven’t yet. Get a cooler large enough to hold drone and put a small amount of ice in a container and put in cooler with drone.  I fly in Florida and know about the heat.
2018-2-25
RedHotPoker
Imovetheearth Posted at 2018-2-25 17:19
If you want, you can test it. Place the cooler packs in the appropriate cooler, and place a regular house thermometer in there. Into the auto. Wrap the thermometer in a towel even. However you choose. Then check it a number of hours later. See where the thermometer reads.
RedHotPoker
2018-2-25
