Weather and altitude
1041 2 2016-7-28
brazilights
Flight distance : 214770 ft
This information is from this website.
Yes, temperature effects airplane performance both the engine itself and the aerodynamics involved.
What Is Density Altitude?
Density altitude is pressure altitude corrected for nonstandard temperature. As temperature and altitude increase, air density decreases. In a sense, it's the altitude at which the airplane "feels" its flying.
How Will High Density Altitude Affect Flight?
On a hot and humid day, the aircraft will accelerate more slowly down the runway, will need to move faster to attain the same lift, and will climb more slowly. The less dense the air, the less lift, the more lackluster the climb, and the longer the distance needed for takeoff and landing. Fewer air molecules in a given volume of air also result in reduced propeller efficiency and therefore reduced net thrust. All of these factors can lead to an accident if the poor performance has not been anticipated.
One way of looking at it is that higher temperatures make the airplane fly the way it would at a higher altitude where the air is less dense. An airplane cannot climb to infinity, it has what is called a service ceiling [and an absolute ceiling] that the aircraft can no longer climb any higher. This also because of a decrease in air density, but for a different reason. Raising the temperature of the air also decreases this air density. You can use an Air Density Calculator or a Density Altitude Chart
2016-7-28
brazilights
Link
http://aviation.stackexchange.com/questions/1531/does-temperature-affect-takeoff-performance
Click on the above link to se the Density Altitude Chart
2016-7-28
DJI-Jamie
Flight distance : 112405 ft
Great information, thank you for sharing!
2016-7-28
